				EJ22 from 01 liberty into brumby
				Posted: Mon Feb 08, 2010 2:41 pm
				by Jason.Rheinberger
				hi guys
found an 01 liberty that has been rear ended
will this motor fit into a brumby?
If not what is the newest EJ 22 i can put in the old girl
Also little bit confused with the whole SOHC and DOHC which one do i need to source in order to make life simple when converting the brumby
				Posted: Mon Feb 08, 2010 3:02 pm
				also thinking of maybe an EJ20
What is the latest make/model i can get the motor out of for the brumby
				Posted: Mon Feb 08, 2010 3:06 pm
				by Alex
				01 libs never came with ej22, in the gen3's theyre either a ej20 sohc or ej25.
you can fit any subaru motor into your brumby, but for any of the EJ's youll need to do sum chassis rail mods.
				Posted: Mon Feb 08, 2010 3:21 pm
				thanks keffa
 the wreckers must not no what he is talking about
I thought that as long as it was SOHC it would fit no worries
can any one clear this up
				Posted: Mon Feb 08, 2010 3:27 pm
				by TOONGA
				only the double overhead cam motors (quad cam/2 cams per head 4  per motor) need the chassis rail cut.
 if it is a single cam engine (2 cams per motor/ one per head) it will fit in with a minimum of fuss and it will be either an EJ20 (2 litre) or and EJ25 (2.5 litre) unless someone did a transplant
a sticky on the subject
showthread.php?t=980&highlight=brumby
ok so this one is an Lseries
showthread.php?t=15754&highlight=brumby
but worth reading
brumby
showthread.php?t=15828&highlight=brumby
donor car questions
showthread.php?t=15426&highlight=brumby
2.5 into brumby by wrxer
showthread.php?t=14033&highlight=brumby
bennies conversion l series
showthread.php?t=11733&highlight=brumby
wrx brumby by SUBIIE
showthread.php?t=13343&highlight=brumby
brumbyrunner
showthread.php?t=4919
just a few from the board
				Posted: Mon Feb 08, 2010 10:37 pm
				by AlpineRaven
				Jason.Rheinberger wrote:thanks keffa
My advice, never believe what wrecker says, you need to see it on your own eyes and also if possible you could check the car where it came from..
				Posted: Tue Feb 09, 2010 2:38 pm
				by Alex
				haah whoops...always read over what you write :P sorry for the wrong info
				Posted: Tue Feb 09, 2010 5:04 pm
				by AndrewT
				You can put a 2010 model EJ into a Brumby if you want. Mechanically all the same principals apply, the only difficult thing is wiring. It get's pretty hairy with the later models I beleive, you would probably have to enlist the help of a professional for this side of things when getting the loom cut down to run.
				Posted: Tue Feb 09, 2010 6:18 pm
				by TOONGA
				in SA this guy wants 799 dollars for an EJ22
http://cgi.ebay.com.au/SUBARU-LIBERTY-2 ... 439cc43ad0
Ive seen whole cars advertised for around the same price  it just depends on the luck of the draw
				Posted: Tue Feb 09, 2010 9:41 pm
				yeah found a few cars jusst not the right one yet
				Posted: Wed Feb 10, 2010 1:17 am
				by maxxair
				89-93 series one liberty EJ22 would be easiest. and cheapest.
				Posted: Wed Feb 10, 2010 2:59 pm
				by Alex
				i picked up a 1991 EJ22 with 180k on it for $250 the other day.
just to put into perspective for you.
