auto radiator use
twilightprotege
auto radiator use
Post by twilightprotege » Wed Jan 13, 2010 7:14 pm
has anyone used an auto radiator (from an 89 L) with tranny cooler on a manual engine and use the tranny cooler part of the radiator for engine oil cooling?
worthwhile? or not?
Post by Gannon » Wed Jan 13, 2010 7:39 pm
I cant see why not.
Where are you going to tap into the oil system?
Post by AlpineRaven » Wed Jan 13, 2010 9:22 pm
I did thought of that a while back when I had automatic radiator in manual, but didn't think it was worth doing, Someone I knew connected up power steering to the radiator and worked as a treat...
If I wanted to cool down engine oil etc I would use external radiator and can be done But with manual transmission, the oil is too thick to be shifted around.
Post by AlpineRaven » Wed Jan 13, 2010 9:23 pm
Suparoo wrote:I cant see why not.
Somewhere I read it off for EJ22, there is two points right under the engine that you can connect up... but you will need to modify the right size valve/connectors etc
Post by steptoe » Thu Jan 14, 2010 8:49 am
is the radiator tranny cooler rated to engine oil pressure. Good thinking out loud though
