Swapped computer over as I had a spare, still the same. What could be causing this, which other sensors should I be looking at, o2, MAF/MAP.
It was running perfectly before I had a bit of work done, (stereo and console work, and a bit of welding, but the battery was out, not too sure about the computer though). Got it back and drove good for a couple of days, then started missing at full throttle in 1st and 2nd. Then driving home yesterday, no good in any gear, and copious amounts of blue smoke. Checked fuel filter, little bit blocked, but not enough to inhibit flow.
