L series heads????
holden26
L series heads????
Post by holden26 » Tue Dec 22, 2009 7:54 pm
Hey, just after a bit of info. Does any one know if the heads off a carbie l series are the same as a fuel injected l series?
Thanks Bodhi
shuffbag
Post by shuffbag » Tue Dec 22, 2009 8:20 pm
nope. efi have twin ports for the intake, carbie share the one intake port
Post by Gannon » Tue Dec 22, 2009 8:20 pm
Nope
MPFI heads have dual inlet ports, carbie heads have single inlet ports
holden26
Post by holden26 » Thu Dec 24, 2009 6:38 pm
damm, are the MPFI heads hard to find? are they expensive? Can i convert to carbie?
Porty
Post by Porty » Thu Dec 24, 2009 8:38 pm
Yeah MPFI heads were a bit of a drama for me to find.. For example, i live on the east coast (NSW) and the only ones i could find were on the west coast (WA).. You may have beta luck but... You could convert to carbie if you were seriously dedicated...!
90 L Series Touring Wagon MPFI
02 GX ImprezaHatch
Post by Gannon » Fri Dec 25, 2009 4:51 am
Whats wrong with your MPFI heads, do they have cracks from overheating?
You should be able to find an 88/89 touring wagon in a wreckers somewhere
phillatdarwin
Post by phillatdarwin » Fri Dec 25, 2009 2:41 pm
there is one in darwin with heads on it at the wreckers 3weeks ago
holden26
Post by holden26 » Fri Dec 25, 2009 2:44 pm
Suparoo wrote:Whats wrong with your MPFI heads, do they have cracks from overheating?
Cracks where the valves seat :( I sent a email to sun spares Subaru but wont have a answer for a few days because of Chrissie holidays
Post by steptoe » Sat Dec 26, 2009 1:28 am
I have a set for my NALPG (carb block, efi heads and manifold) set up and they too are cracked between the valves even leak petrol when I do the old valve test on their side and poor petrol into intake and exhaust ports to check valvers YET when machine shop did their vacuum test they come up alright - meaning sometimes those cracks do no harm...
Post by Gannon » Sat Dec 26, 2009 7:19 am
Nearly every EA82 that has done more than 50,000km has them. 99% of the time they are cosmetic and will cause no harm
shuffbag
Post by shuffbag » Sat Dec 26, 2009 12:08 pm
but i cant see why you couldnt use the heads (some one correct me if im wrong).
you would need to use the efi manifold and block the holes for the injectors/modify the top for a carby.
spike
Post by spike » Sat Dec 26, 2009 2:43 pm
we thought about it earlyier today as we pulled my ea82 race motor out.
you can use the heads in theory but need new intake and exhaust but aat that stage might aswell use the head use a different intake to have twin carbies (much cheaper than having one for a single made or modified) and custom exhaust
holden26
Post by holden26 » Mon Dec 28, 2009 1:44 pm
Thanks every one ill get the head checked out and see if its alright
Post by Gannon » Mon Dec 28, 2009 4:18 pm
Unless you have overheated it, it'll be fine
There was a Technical Service Bulletin released by Subaru years ago saying that they are only cosmetic in nature
I'll see if i can find it
Post by steptoe » Mon Dec 28, 2009 4:27 pm
I know a fella that cut his teeth on our old beloved L Series at a dealership, reckons he saw a few cracks with low mileage and reckoned there was the OK to shove 'em back on and when new head gaskets went on so too did a lot of three bond gasket goo :) (can't seem to find this tip in the factory manuals)
The Tech Bulletin would make a good read
holden26
Post by holden26 » Wed Dec 30, 2009 7:37 pm
Suparoo wrote:Unless you have overheated it, it'll be fine
Alright ill give it a try, does anyone sell just a head gasket? cause everywhere i have rang says that they don't sell just the gasket anymore and that i can only get it as a VRS
wrxer
Post by wrxer » Wed Dec 30, 2009 8:36 pm
heaps on ebay, if not australia then usa for sure
Post by steptoe » Thu Dec 31, 2009 1:54 pm
the autopro parts chain has supplied just one head gsaket at a time (I did order two though) through their buying group. The brand from memory was Boric. Mounted on cardboard backing, no address or country of origin. Subaru do plain old head gaskets for EA82 and sell or order and supply separately.
nncoolg
Post by nncoolg » Mon Jul 27, 2015 6:42 pm
The Bulletin:
[The extension pdf has been deactivated and can no longer be displayed.]
# EA82 AWD 4EAT,
