Converting dual range 4WD L-series from 3.7 to 3.9
Posted: Mon Feb 27, 2006 10:47 pm
I've just brought home an '85 model L-series that is only high range 4WD through the push button on the gearshift. This operates on the 3.9 diff ratio. However, my project car is a '91 model, has 3.7 diff's in it and it's a dual range gearbox.
While both are manual cars I wondered if it was possible to change the dual range to 3.9 easily using some of the older car's gearbox parts? Is the fact that one is single range and the other is dual range going to be a problem?
