the importance of quality coolant
Joel
Post by Joel » Sun Nov 29, 2009 1:37 pm
Hey all,
thought you might be interested in seeing what happened to my engine
its a harsh reminder of how critical cooling system maintaince is
I picked up my EJ22 earlier this year and it has been running beautifully but i dropped it out to replace a gearbox seal a few months ago and had a bit of an air lock after i put it back in
it was still running sweet but was getting hot around town
overflow bottle kept bubbling and filling up when it got hot so i pulled it out to replace the head gaskets
heres what i found....
both heads and the block are a total write off
#1 cylinder its almost eaten through to the bore
it had nice clean coolant in it when i pulled it from the liberty but anything could have been in it for the 16 years before that
Post by TOONGA » Sun Nov 29, 2009 3:12 pm
well thats a mess I know people are going to say Im speaking rubbish but coolant can actually cause that sort of damage as well
if the wrong sort is used or it is too strong it eats away the engine
there is only one real way to stop the electrolitic process in an engine and thats with sacrificial metal and the right coolant
a 1mm thick 10 mm wide and 150mm long zinc strip placed after the thermostat into the radiator hose or even into the radiator stops the process for a fair while but the downside is the crap that gets created by the eletrolization process
so the options use coolant and have a c clean motor with a chance of corrosion anyway
or use zinc stop the process but end up with sludge in youe engine (which can be cleaned out)
Post by El_Freddo » Sun Nov 29, 2009 9:26 pm
That's carnage!
Bugger.
subybrumby
Post by subybrumby » Mon Nov 30, 2009 6:24 pm
I use castrol coolant in the small bottle, used to be a small can with a ring pull in the top. Now in a small plastic bottle with a twist lid. never had any worries in any of my cars with it.
Wraith
Post by Wraith » Mon Nov 30, 2009 7:43 pm
Wtf was the previous owner using as coolant??? Battery acid???
Bloody hell, i have never seen anything like that....
The coolant in my lib is over 3 year old.....
Guess what im doing this weekend....
Destroy waves, NOT beaches.
1990 L Sportswagon (Mine)
1988 L Touringwagon (Hers)
1998 Liberty GX Wagon (Ours)
1987 L Touringwagon (SOLD!!)
1986 L Jap Import Turbo wagon (SOLD TO TIMMO!!)
1986 L RX Turbo wreck (SOLD TO TIMMO!!!)
Joel
Post by Joel » Mon Nov 30, 2009 8:44 pm
coolant lol
its just the electrolosis process at its worst
damage looks worse than it is in spots cos theres remnants of the old headgasket there looking pretty tradgic
i dont think this motor had ever been apart let alone out of the car
it wasnt a high milage at all, only 147k in fact and i think the problem was actually due to this
the lady that had owned it only did small amounts of KMs each year so it went for years between scheduled services so it was probably lucky to see a coolant change once every 5 years
drof351
Post by drof351 » Mon Nov 30, 2009 11:35 pm
Isn't electrolysis caused by stray current? If so your coolant consistency if its to strong or weak wont make a difference it means you have a bad earth?
iananita
Post by iananita » Tue Dec 01, 2009 4:00 pm
What km's has the engine done?
FROG
Post by FROG » Tue Dec 01, 2009 4:39 pm
Funnily (or not really) that's exactly what my old libs internals looked like when I stripped it down at three hundred odd thousand klms , it was the last thing I wanted to see Even looks like the same place I'll try and find the pics tomorrow
Post by AlpineRaven » Tue Dec 01, 2009 4:54 pm
geee what a mess there, not the first time ive seen this, happened to me once in the past, engine would heat up badly while idling or in traffic and it blew headgasket and when i did the headgasket i found the problems, it was blocked and the engine/heads were write off too. It was cast iron engine with alloy heads...
That is why I am very precise what I put in my cars and I am a real pain in the arse what I buy!
FROG
Post by FROG » Wed Dec 02, 2009 12:31 pm
Does this look familiar?????????????
Joel
Post by Joel » Sun Dec 06, 2009 9:35 pm
sadly yes, altho mine was like that only worse on both sides and both heads :rolleyes:
its a credit to the engines though that it kept running pretty well perfectly fine like this
it was just getting hot around town then i noticed the caramel milkshake under the oil cap
