EJ throttlebody fasteners , bolts or cap screws ?
- discopotato03
Hi all , I need to know if early (90's) era EJ20's and EJ22's bolt their throttlebodies up with bolts or allen head cap screws .
Also can anyone tell me which ones have the two wire rotary idle air control valve rather than a stepper motor .
Cheers Adrian .
Cheers Adrian .
- FROG
At work at the moment and they look to be flange bolts
- discopotato03
Good , as I hoped .
Now to the idle air control valve in the throttlebody .
I've been reading that in about 1999 the EJ went through control system changes and about this stage the IAC went from a rotary valve in the throttlebody to a bolt on housing with a stepper motor for idle air control .
I need to find the early type throttle body with the rotary idle air control valve and the gadget that moves it .
I'm going to drag an EA82 spider plenum to the wreckers to try to match up an EJ TB to it becayuse its the simplest most compact way to do idle air control .
Cheers A .
Cheers A .
- FROG
april 98 onwards i believe
- discopotato03
Google images is your friend
I think these are the two types you are referring to.
Integrated into the throttle body
Separate to the throttle body
The later turbo models ( i think)
- discopotato03
- discopotato03
Ahh , now they're cooking with the Gas .
http://forums.nasioc.com/forums/showthr ... light=iacv
These pics at Nasioc pretty much show me what these things are .
The only thing is I was asked to look for a two wire one .
Cheers A .
Cheers A .
