outback tappet cover gasket
does anyone know can the tappet cover gaskets be changed on and subaru outback engine while the motors is still in the car
									[SIGPIC]
In a Gen2 with its DOHC EJ25, probably not.
In a Gen3 with the SOHC EJ25, maybe. It might involve undoing the engine mounts and lifting the engine a few inches
i might be wrong, i don't know about sohc, i think you can change it while its in car.
Based on EJ22 You can change the gaskets while in car, without moving anything. I suspect EJ25 SOHC should be the same. But with DOHC it might be more complicated?
bit fiddly i'd imagine.... I've done plugs a few times on dohc and h6 engines, I reckon anything is possible with patience.
The covers are aluminium alloy aren't they? when they are off you should polish them.... I know nobody will see them but its just a fun thing to have shiny shiny mirror finish bits on your engine lol.
Robert.
Robert.
I have lol.. Yeah you can polish it up. Its a pain in the arse job bec by end of the week it needs polishing again. Same with me i also did a diff cover as well, didn't stay polished.rob83ke70 wrote:bit fiddly i'd imagine.... I've done plugs a few times on dohc and h6 engines, I reckon anything is possible with patience.
Robert.
- bobbyjimmy
check this thread -camo85 wrote:thanks for replys how do i tell dohc to sohc can you tell by engine no. ej25DNWDJA
showthread.php?t=14495&highlight=dohc
I have posted two photos - that will give you best idea of what engine you have.
