Liberty Gen 2 Auto into Gen 1
Posted: Sat Nov 14, 2009 8:20 pm
by Matt
Will a Liberty Gen 2 Auto bolt onto Gen 1? This is will a Auto out of a Gen 2 1994 Liberty bolt up to a Gen 1 1993 Liberty?
The auto in question is a 4 bolt model.
Thanks
Matt
Posted: Sat Nov 14, 2009 8:22 pm
by Gannon
Should do. The Gen1 and Gen2 are basically the same platform. Just double check the wiring pinouts. Im guessing both engines are EJ22's
Posted: Sat Nov 14, 2009 8:27 pm
by Matt
Unsure on the liberty it is going into.
Also the auto is manual control, not computer???
Posted: Sat Nov 14, 2009 9:06 pm
by AlpineRaven
Its a 4 bolt so it'll work.
Both engines are EJ22.
The connections are different but if you have existing tranmission, just swap the wiring/plugs over.
I don't know about the final drive, but I'm pretty sure its 4.11.
Edit: For sure Gen 1 has 4.11, but I'm pretty sure Gen 2 also has 4.11 as well.
Posted: Sat Nov 14, 2009 9:22 pm
by Gannon
All EJ auto's (4eat as they are known) are computer controlled. They will simply not work right without the TCU
Posted: Sun Nov 15, 2009 7:39 am
by Matt
I thought they where computer controlled or controlled be the TCU.
Posted: Sun Nov 15, 2009 11:36 am
by vincentvega
Matt wrote:Will a Liberty Gen 2 Auto bolt onto Gen 1? This is will a Auto out of a Gen 2 1994 Liberty bolt up to a Gen 1 1993 Liberty?
Thanks
Matt
bolt the box up, plug it in and drive. no modifications required.
Posted: Sun Nov 15, 2009 11:38 am
by vincentvega
Wrong. They are the same.
Posted: Sun Nov 15, 2009 12:27 pm
by Matt
Thanks fella's that is the answer i thought you would say, is that it will bolt up and will be driveable.
