EJ20TT into Brumby -Can I make it a EJ20
Posted: Sat Oct 10, 2009 8:47 pm
Howdy,
I have a EJ20TT Jap import Donk sitting in the shed for about 9 months now. I pulled it from an import front cut. The old ea81 boat anchor is struggling with the 200km per day trip to work and back. Since I have everything from the front cut, though might as well put it to use. I don't want to install the turbo's. Can I simply unbolt and remove everything associated with the turbo's and run the motor as more or less an ej20? I have the Loom and ecu that came with the ej22tt front cut, if I do install the donk with the turbo's removed, can I still use the factory ecu or do I need to source one fron a factory ej20?
