Charcoal Canister, what does it do
G'Day All,
I had a search back through the old threads but couldn't find what the charcoal canister does?
I've got a little bit of flat spotting and suspect a dirty injector but found that the outlet or inlet to the canister had broken off, could this cause a flooding effect? (Having one line disconnected?)
Any comments greatly appreciated.
G'day Dane,
The charcoal canister filters fuel vapour from the fuel tank - there will be an inlet (from the tank) and a purge outlet to the inlet manifold/intake depending on the set-up. The EJ22 looks like it's got a little pressure valve on the inlet line from the tank, it'll open as fuel in the tank evaporates and pressurises the system.
If the purge outlet to the inlet manifold is sucking in air that is not metered by the AFM then that might just be your problem. Block it off and see what happens I reckon.
Jake.
Jake.
- phillatdarwin
- d_generate
I had a 99 WRX and one of the hoses going to the the canister kept falling off, car would run like poo without it attached, not much help but I know it made a huge difference on the way that car ran.
why the **** would anyone want to block off the charcoal canister???phillatdarwin wrote:all that on my L dose not work any more just all block and there for good looks .
small steel balls just the right size of the inside of the hose job done still looks the same but not working .
Its all part of the fuel tank closed environment, it scavenges vapour from the fuel tank, the purge valve is opened in engine vacuum conditions so it also
goes to helping drive your car down the road, you paid for that vapour so why not use it, otherwise its bloody stupid just letting unused fuel vapour escaping to the environment like that:(.
Also, with a properly sealed re-fill cap,when you open the fuel refiller to re-fuel, there should not be a great rush of pressure of vapour, of course there is some vapour thats unavoidable.
In nsw there is a move to get service stations retrofitted with a vapour capture thingto avoid that also.
A move ? It might work now a few more people are scared of the climate change being for the worse not the better. A fellow invented a vapour scavengng/recovery system for those sometimes concealed outlet pipes at your local servo nearly twenty years ago and it was allegedly banned or rejected by governments and/or fuel companies from what I vaguely remember. Some companies had these pipes fitted to their big company logo signs up on big poles, some have them out the back.
from my tests, (removing it and trying)
it just forces the vapour back into a liquid form to be made vapour in the carby.
i think it ,makes the fuel a little faster flowing, basicly takes up space and makes sure that all the fumes are burnt and not released to atmosphere. just for enviromentally concious jargon
