EJ gearbox with DR and locking center diff ?
- discopotato03
This thread was pointed out to me over at USMB .
Since the native DR locking EJ18 boxes are kicking around in NZ I thought a few of you would be interested .
Don't know how strong they'd be or if they'd hack turbo torque in an EJ weight car , only one way to find out .
Cheers A .
http://www.ultimatesubaru.org/forum/sho ... p?t=103125
Cheers A .
I dont think there is centre diff locker in EJ gearbox?
Edit - After reading thru the posts, I think its an EA box with diff locker in it... I havent seen an EJ box with diff locker because if there was one I would have it by now!
- discopotato03
The go would be to get pics of the linkage side of the complete gearbox , that way you could see if it was a "long" EJ type box with the diff locks fork linkage . The EA type AWD rear extension is different/shorter because the center diff is behind the transfer gears not in front of like in an EJ's gearbox .
BTW by "transfer gears" mean the pair that take the drive back up to the rear output shaft not the hi/low transfer gears .
The right pics should give the game away .
Some people in Victoria (Gareth) found a way to do a locking center diff conversion to an EJ AWD type box but it still had teething problems last time I asked him about it .
Assuming the Kiwi box is a real one you should be able to build a reasonably strong box around it , it may be as simple as changing the extension over with its different guts .
Interesting times , cheers A .
If there is locking centre diff in EJ box, then i would be interested.discopotato03 wrote:The go would be to get pics of the linkage side of the complete gearbox , that way you could see if it was a "long" EJ type box with the diff locks fork linkage . The EA type AWD rear extension is different/shorter because the center diff is behind the transfer gears not in front of like in an EJ's gearbox .
I'll ask kiwishooter again if he could provide photos.
- discopotato03
Well Kiwishooter went on to say they are an EJ gearbox and knows of them still bolted into Legy's .
Save your money up , cheers A .
Actually you may want to ask him if there is a factory WSM available with all the ratio etc specs , maybe the VIN number of one could help out .
One of his pics shows the ID sticker on a gearbox so could search that as well .
