				EJ22 cold start trouble
				Posted: Fri Aug 21, 2009 1:23 am
				by EJ22Ute
				on cold mornings the motor takes several attempts to start, sometimes over a minute of intermittent cranks.
have cleaned MAF wire element. checked plugs and leads, used injector cleaner.
valve seals are worn and not sure about coil packs and oxy sensor.
any suggestions?
				Posted: Fri Aug 21, 2009 5:58 am
				by Outback bloke
				Who stripped your wiring loom? How is it wired in?
				Posted: Fri Aug 21, 2009 6:19 am
				by AlpineRaven
				is the crank sensor in good condition? Is the battery working well? Same with starter motor. I would be checking the starter motor area, if you have a spare one swap it over see how it goes.
				Posted: Fri Aug 21, 2009 8:18 am
				by Outback bloke
				It sounds to me like the sense wire from the starter to the ecu is not connected. Also could be a fuel pressure thing or even an ecu thing.
When you try to start it, turn the ingition on and wait until you hear the fuel pump relay click off. Turn the ignition off and then back on again. Wait until you hear the pump relay stop again and then try to start it.
Big question is, has it alwasys been like this since the conversion?
				Posted: Fri Aug 21, 2009 10:32 am
				by SUBYDAZZ
				Are you getting any codes? Crank angle sensor does come to mind, but it is usually an issue when it's hot, not cold. It should get a code in memory if it is the issue though.
				Posted: Sat Sep 05, 2009 1:25 pm
				by EJ22Ute
				it has been a problem since install but only when very cold morning.
no code wires were working when trying to check for faults.
harness was done by third party no longer operating
