Brumby Throttle Sticks
rossandhazel16
Post by rossandhazel16 » Thu Jul 23, 2009 1:39 pm
I have a 90 Brumby. On the odd occasions the throttle will stick on. This seems to happen on really cold days until the engine warms up but doesnt do it all the time. Jams up on full noise and gets a little exiting.:confused: Stop and have a look and nothing to see as it has unjammed????
Feel like it has something to do with the choke??? The hose from the exhaust to the aircleaner is not there also. Any ideas please.
phillatdarwin
Post by phillatdarwin » Thu Jul 23, 2009 10:34 pm
it is your auto choke doing that to u
Post by El_Freddo » Fri Jul 24, 2009 4:30 pm
phillatdarwin wrote:it is your auto choke doing that to u
I'll second that. You can loosen the screws and twist the auto choke casing to release some of the tension on the spring, this might help - if you have a manual best to consult it for correct adjustment.
The pipe from the air filter to the exhaust is for warm air in the cold - it helps the engine warm up and stops the fuel from freezing as it changes velocity (thus cooling) in the carbie in cold weather...
All the best with it.
1990Brumby
Post by 1990Brumby » Sun Jul 26, 2009 8:06 pm
Had this happen to me in my previous brumby, But it had also developed constant vacuum every ware causing the choke and everything to just stay on.
