Auto trans leaks into front diff
stephendean
Post by stephendean » Mon Jun 08, 2009 4:34 pm
Yet again my trans is pumping fuild into the front diff, which then comes out of the filler tube then on to the exhaust. Lovely smell, not. Does anyone know what would cause an auto trans to pump fuild into the diff. Steve at rising sun has replaced seals and o-rings a few times. But it has just happened again on Saturday. Would like to solve problem, as it makes it difficult to get to work(when I get any).
Post by steptoe » Mon Jun 08, 2009 4:59 pm
You'd think if anyone would know , it would be Steve. Cannot recall if an auto has a breather like manuals and diffs. If they get blocked or breather hose gets crimped it can lead to pressure inside, causing fluid to get out the easiest path. I'd check back with Steve
vincentvega
Post by vincentvega » Mon Jun 08, 2009 7:19 pm
you have changed the back to back seals and it still leaks?
chubby37
Post by chubby37 » Mon Jun 08, 2009 8:06 pm
my old L auto did the same thing...there is a plate with seals that devide the box from the diff....that stuffed out on mine....cure...changed to 5 speed...auto never leaked again
Post by TOONGA » Mon Jun 08, 2009 9:24 pm
sounds like you have excessive pressure in the box whixch is causing the seals to fail especially if its filling the transaxle to overflowing out the filler tube
what type of car is the box in?
stephendean
Post by stephendean » Mon Jun 08, 2009 9:43 pm
It;s in a "L" series subby. 5-speed would be nice but I don't think I could afford to at the moment. Would rather get the auto fixed, then later on think about another car when I am earning some money.
Post by steptoe » Tue Jun 09, 2009 4:41 pm
I'm sorry to say, my fix was the same as chubbys - went to a manual 5 speed and the leak stopped. Bought the whole car for $250 so given all the spares I got off it for that and all the goodies I have tossed, it was cheaper than paying anyone to R & R the box and fix it. May be the case for you too.
