L front shaft length question
Posted: Fri Feb 20, 2009 11:13 pm
by brumbyrunner
Can anyone tell me the length of a front L series driveshaft? Not with joints on it, just the bare shaft. It should be 23 spline unless it's off a part time turbo manual in which case it should be 25 spline.
I only have one and it measures 453mm which confuses me as all my MY fronts are 451mm long. Surely they are not the same? The rears are very different lengths.
Posted: Fri Feb 20, 2009 11:41 pm
by Matatak
ive got one with the 2 raised bands that measures up at approx 495mm.
i used it for Lseries c. arms in my MY
Posted: Sat Feb 21, 2009 1:39 am
by AndrewT
brumbyrunner sounds like you actually have another MY shaft there. A few mm here and there is the subtle difference between models.
Posted: Sat Feb 21, 2009 7:44 am
by brumbyrunner
Thanks guys, I thought the shaft I had came out of my L series but it must have got mixed up. Matataks shaft is 42-44mm longer than the MY which is consistant with the rears that are 37mm longer.
Posted: Sat Feb 21, 2009 7:55 am
by brumbyrunner
Matatak wrote:ive got one with the 2 raised bands that measures up at approx 495mm.
Hey Matatak, has that shaft got 23 splines?
Posted: Sat Feb 21, 2009 11:04 am
by Matatak
it does indeed.
