Rear Diff
caboolture
Rear Diff
Post by caboolture » Sat Jan 31, 2009 12:22 am
Ok here is the plan for a 91 liberty transplant. 92 RS turbo motor with 91 dual range gearbox with a 4:11 diff or 3:9 diff. What i would like to know is the difference. It will be used mainly for on road use. Cheers Peter
1991 gx 3" lift 16" gt Forester alloys,215/65/16 outback struts and pedders raised springs, Turbo motor,gearbox,diff,brakes,bonnet etc now transplanted :D
Matatak
Post by Matatak » Sat Jan 31, 2009 1:34 am
the rear diff will have to match the box. (which id say is more than likely going to be 3.9 if a manual DR)
so you cant just choose what diff you want to use as it wont like it if its not suited to the box.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
discopotato03
Post by discopotato03 » Sat Jan 31, 2009 8:07 am
I look at most of these Nissan and Subaru final drive ratios as being approximately 5% gaps .
If you multiply 3.9 by 1.05 you get 4.095 . If you divide 4.111 by 3.9 you get 1.054 .
A .
brumbyrunner
Post by brumbyrunner » Sat Jan 31, 2009 10:33 am
When you're caculating gearing you need to look at the gearbox ratios as well as the diff ratio. I've mixed and matched to get the lowest possible gearing from factory ratios but for your application, you might not want that.
Are you happy with your gearing now? Unless it's been changed you will have:
1st 3.545
2nd 2.111
3rd 1.448
4th 1.088
5th 0.871
Diff 3.9:1
Low 1.196:1
Settlement Creek Racing
Post by AlpineRaven » Mon Feb 02, 2009 8:58 pm
It would be 3.9 if its gen1 D/R box. if it was automatic it would be 4.11
