Sleeving a EJ20 turbo
Posted: Sat Jan 17, 2009 11:12 pm
by Morcs
Has any body heard of replacing the 2ltr (92.5mm)sleeves with 2.5s(100mm)
In an early EJ 20 (94) Thought these are a closed deck motor.
Looking at doing a rebuild or a 2nd hand motor thought if i rebuild it might see if i could push it out to 2.5l
Trying to weigh up which way is going to be the best way to go
As pistons and rods are the same price for both sizes.
Also going to put a Hi Flowed TD05h turbo on it.
Posted: Sun Jan 18, 2009 12:26 am
by Outback bloke
I looked in to it. It can be done but it is not recommended. Once the block is bored to fit the 2.5 sleeves it actually becomes very close to entering the water jackets.
You need to talk to Robin at Perfourmance Motorsports at
http://www.pms.net.au/
He is the closest thing I know to a guru on doing this sort of thing. He is the person that fitted diesel sleaves to my 2.5NA and closed the deck on it.
Posted: Sun Jan 18, 2009 7:02 am
by Gannon
check out rslibertyclub.org
The guys over there will explain the best way to do it.
I think that an EJ22 with EJ25 crank give 2.35L which seems to be common over there
Posted: Sun Jan 18, 2009 8:16 am
by Outback bloke
No offense but most of the guys over there buy their motors. They aren't actually the ones that build them. They simply buy what others have had built. Sure talk to them and get their opinion on how they run and what not.
PMS on the other hand has built all these sorts of motors and experimented with different combos. 1 bloke lots of motors sort of gives you the best idea on what is good and what is shit.
Posted: Sun Jan 18, 2009 11:19 am
by AndrewT
Yeah be careful of misinformation on there. However there are a few genuine gurus there too. Oversteer is a member, he used to frequent this forum too. He recently ran an 11.2 quarter mile in his Legacy on the EJ22 based motor he built himself. I think it's one of the fastest automatic libs in Australia now. Here are the specs for his motor;
2.2 stroked(with 2.5 crank) = 2.35 short motor
- High volume oil pump(JUN copy)
- ACL race bearings *special clearances*
- CP 2.35 pistons
- Argo rods
- Tomei baffle/block strengthening kit
- ARP 11mm stud kit
02 STI heads
- Ferrea valve train
- JUN 272 cams
- JUN cam wheels
- Genuine 22b head gaskets
Other bits
- Manifold, modified 02 sti, 64mm TB.
- GT3076R
- 44mm Tial
- Headers 4-1 un-equal
- Custom up-pipe&screamer
- Custom fuel system, Sard reg, Defi FP Gauge
- Motec M800
And the video of the run;
http://members.iinet.net.au/~zrinski/wags1125.wmv
Posted: Tue Jan 20, 2009 1:26 am
by Morcs
Thinking along those lines wanted to retain reliabilaty set of ported/cammed heads may be a better option.
Along with a set of forgies, good quality rods and stud kit.
