L series tailshafts
Posted: Sun Jan 11, 2009 6:17 pm
by PeeJay
Is it possible to fix these? I've got one with a loose uni joint and a dodgy bearing that will soon need replacing.
Posted: Wed Jan 14, 2009 3:32 pm
by Lang
In my area no one would replace the uni joints on 'L' series, litigation I guess, try Sun Spares Qld. Their good. You may be able to get a replacement uni with an inner C clip and then grind the old one out, usually the front, but I'd go s/h.
Posted: Wed Jan 14, 2009 4:11 pm
I've heard you can replace the uni joints - you need to take it to a shop to do it. I think its the WA boys that have done this.
Posted: Wed Jan 14, 2009 4:31 pm
by stamp_licker
A driveshaft shop will replace it for you,normally by putting in a new yoke and uni, but if you need to do more than 2 uni's it usually works out cheaper to get a whole new shaft built.
Posted: Wed Jan 14, 2009 6:37 pm
by PeeJay
Hmmm... I've changed the uni joints on an MY shaft before so maybe it's time to convert to a 1 piece shaft.
Posted: Wed Jan 14, 2009 7:03 pm
by AlpineRaven
You can do it but there is a trick - ive done it before but i cannot remember. If you're unsure take it to the shop, be aware make sure you put the tailshaft in right side, if you invert, it can upset the balance.
Posted: Thu Jan 15, 2009 10:20 am
by discopotato03
You basically need the unis back and front from an early Datsun , 5 spd Bluebird Ser 1/2/3 use the same type of gearbox slip joint and the spider is replacable .
Having a Nissan R160 rear diff also means a rear uni from a 1600/180B and they have replacable spiders/bearing cups as well .
By invert I guess you mean the center bearings "hoop" .
I may be guilty of this one , if its inverted does it move the bearing higher or lower than in the correct position ?
Cheers A .
Posted: Thu Jan 15, 2009 4:54 pm
I have replaced a similar staked uni joint in the steering shaft in my Brumby. Found a un to match size wise and just tack welded the little thing in place. I would not try a tailshaft uni for balance purposes unless desperate.
Posted: Thu Jan 15, 2009 9:19 pm
by AndrewT
Any decent tailshaft/driveshaft place can replace the "non-replaceable" subaru joints with a "replaceable" type.
