Speed Sensor - may be related to speedo cable?
Posted: Thu Nov 13, 2008 8:08 pm
by stephendean
On my "L" series MPFI auto, the check light has come on. I have read the code and it indicates a problem with the speed sensor. does anyone know where this beast lives? And is it ok to drive while I collect money to pay for parts and/or repairs?
Posted: Thu Nov 13, 2008 8:12 pm
by jzk25
Does the speedo still work?
The speed signal is generated by a reed switch in the back of the instrument cluster.
Posted: Fri Nov 14, 2008 8:58 am
by stephendean
No the speedo stopped working the day before
Posted: Fri Nov 14, 2008 10:32 am
by daza
Then it's most likely just a broken speedo cable, replace it and see if the code returns.
Daza.
stephendean wrote:No the speedo stopped working the day before
Posted: Sun Nov 16, 2008 11:41 am
by OKsubaru
This is something I have been trying to learn about !
stephendean, a question for you. Did you notice any drivability issue before seeing ecu light come on on the dash? or have you driven it to pick up your parts and noticed any significanrt change ? Oh, has the speedo cable simply come away from the back of the speedo unit then? r come out somehow at the box?
I did find photoos and discussion in here about the L speed sensor being in the speedo unit itself of efi and other L series. Think i searched speed sensor
