The Gearbox Thread
Posted: Mon Nov 03, 2008 8:01 pm
by stamp_licker
Thought i'd start this to get a bit of info on different box setups for different subaroos offroad.Basically describe your g/box and mods if any and its pro's and cons.
I'll start
Originally 4eat with a vtd rear and 4.44 diffs.
Pro's :awesome offroad ,very capabale in mosts situations,lockable centre.
Cons :$ to setup and get working right/reliable in a L series
New box:AWD EJ dual range,l series low range,4.11 diff
Pro's :?
Cons :?
Posted: Mon Nov 03, 2008 8:12 pm
by Xtreme_RX
My Gearbox->
AWD 5 Spd 'L' series casing 4.111 diff with 'RA' 1st & 2nd + 1.59 Low range fully overhauled. Lib Spedo gears.
Pro's: Dam low gearing - crawls everywhere hardly need to use Low. AWD. Easy on the clutch.
Cons: Was expensive to build. A bit of machining to make it all work. Cant lock center diff
by vincentvega
1997 4.11 4EAT. VTD rear end. 4.44 diffs. early outback speedo gears. early WRX TCU
Pros: great offroad. lockable center. ability to ease power on to gently climb obstacles. no need to dump the clutch like a manual. outback speedo gears means my speedo is correct. 4.44 ratios on a 4.11 box put gearing back to stock with big tyres. huge improvement in fuel efficiency and driveability. VTD rear end means lots of rear wheel drive which is great for climbing hills.
cons: expensive to set up. have spent about 3k on this box (parts + full rebuild) however it now appears to be bullet proof. autos chew fuel around town. better on the highway though once the converter is locked up. averaged under 10L/100kms on the trip out west this year.
manual box - dont do it posty ;)
Posted: Mon Nov 03, 2008 8:28 pm
by Captain Obvious
Standard 1993 Liberty dual range no mods at all 3.9ratio
pro's: cheap to replace not to bad offroad, ej20t has the power to compensate for tall low range!!
con's: not really low enough for hill climb crawling......
