urgenturgenturgent
creeture3
urgenturgenturgent
Post by creeture3 » Fri Oct 31, 2008 8:14 pm
The crankshaft pulley bolt ('98 Liberty Rx / 2.5L / non-turbo / AWD / quad cam): left or right hand thread??????
...............HEEEELLLLPPPP............:confused::confused::confused::confused:
chubby37
Post by chubby37 » Fri Oct 31, 2008 8:38 pm
should be anti clockwise to undo it
creeture3
Post by creeture3 » Fri Oct 31, 2008 8:50 pm
Thank you chubby37. I will try using a longer "breaker bar":twisted:
It stands to reason if the engine turns clockwise, the "main" bolt will turn anti-clockwise to undo.
Just checking before I bring in the big guns!!!!!!
I must say the bolt is effing tight:mad:
chubby37
Post by chubby37 » Fri Oct 31, 2008 9:05 pm
yeah they are...try putting it in gear and park brake on then try to undo it.....first thing tho...disconnect the battery...you dont want it to for some wierd reason try to start with you connected to it
Ben
Post by Ben » Fri Oct 31, 2008 9:24 pm
Disconnect igniter power lead, put breaker bar on bolt with handle end resting on the chassis rail of the car and tap the starter. Car won't start but will crack the bolt.
Please watch before posting!
CPOCSM
Post by CPOCSM » Sat Nov 01, 2008 7:51 am
Shouldn't be too tight - I recollect 75 ft/lb is the torque setting(try doing a mini box spigot bolt @ 200ft/lb!!!). The previouos owner may have put loctite on it so is difficult to remove. They also could have a large silverback gorilla they use to tighten the bolts up(BMC had the MOWOG logo stamped on a lot of their parts - rumour has it that this was the name of the aforementioned gorilla that did all the bolts and nuts up wayyyyyy too tight)
Good luck - breaker bars are your friend - up there with FBH's
Hooroo
Rob Forsyth
Post by Subafury » Sat Nov 01, 2008 2:53 pm
breaker bar- possible extension for your breaker bar then hit it with a big hammer on the end. should do the trick. same to tighten
Post by D3V1L » Sat Nov 01, 2008 4:02 pm
rest the breaker bar on the chassis rail and tap the starter motor... did it on my cruiser this morning and works a treat
dave
Matatak
Post by Matatak » Sat Nov 01, 2008 4:14 pm
D3V1L wrote:rest the breaker bar on the chassis rail and tap the starter motor... did it on my cruiser this morning and works a treat
dave
the problem with that is then doing it back up....
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
creeture3
Post by creeture3 » Sat Nov 01, 2008 7:15 pm
thanks for all the advice. Finaly had to stop the engine turning by putting a bar into the drive plate bolt holes, and used a 3 foot "extension" on my breaker bar. Did the trick, but I was a bit worried for a while there!
