Bugger!!!!
Posted: Sun Aug 17, 2008 11:09 pm
Think I found out why the gearbox was playing up a bit. Did the full service thing with new fluids and bits and pieces...came to draining the box and knowing that it holds 1.8 litres of fluid, I used the smaller 2.5 litre drop pan.
Thank heavens I was having a bit of a lie down under the car when I saw the fluid level getting to the top of the catch pan...quickly grabbed the 5 litre one and switched them over...the gearbox had 5 LITRES of oil in it...that would have nearly filled it to the top of the dipper tube in my thinking.
Well I rang the "subaru specialised business" here in the ACT who did the box service last time and they could offer no excuse as to why they overfilled it. Suffice to say I now have a weeping output shaft seal on the starboard side of the box and a very big mess on my cat converter. After my tyrade on the phone, the "business" is replacing the seals and cleaning the cat converter. Really pisses me off when the experts cant even get it right. The box is completely different in feel and no clunking of gears now. There was a heap of swarf on the drain plug but I think that is normal(was more like grey grease than filings...you should see a minis sump plug - looks like it has an afro!!)and adjusted the advance to 19 degs as the fuel quality here is poop and pings like a bastard.
I have also reclaimed my garage from the packing box monsters...only took me 7 months but I can now see the mini and touch it again - even sat in the drivers seat...gawd I miss the registered go-kart!!
Hooroo
Hooroo
