drive pinion shaft removal
- chubby37
anyone know how to get the drive pinion shaft out of a FWD auto ej22 trans....need to replace the bearing on the shaft
- steve_rising_sun
- chubby37
wow that was easy once your told how it comes appart...cheers steve...bearings seem to look ok but there is play....cant see any other possible couse for metal filings in diff fluid so i say its the bearings....steve,how much you charge for the bearings to do the job...pinion and both drive shaft bearings...thanks
- steve_rising_sun
- vincentvega
