how to tell if its a dohc or sohc
heath
Post by heath » Sat Jul 19, 2008 8:21 pm
i no i propebly sound stupid asking this but can someone tell me how to tell the diffrence between a dohc and a sohc ej20. or show me with a couple of pics
Outback bloke
Post by Outback bloke » Sat Jul 19, 2008 8:54 pm
You just look at the timing covers on the front. A SOHC will have small covers that are simply round on the outer ends. A DOHC will have large covers that are kind of flat on the ends.
rob83ke70
Post by rob83ke70 » Sun Jul 20, 2008 8:14 am
get a 10mm 3/8" socket small extension and ratchet, take three bolts off the small timing cover on the passengers side of the engine, if there is one cam sprocket underneath, it is SOHC if there is two (and possibly more bolts to undo on the cover or different style of cover) then it is DOHC. SOHC is much much nicer to replace a timing belt on :)
Post by Gannon » Sun Jul 20, 2008 8:52 am
DOHC
SOHC
heath
Post by heath » Sun Jul 20, 2008 9:26 am
thanks for that info and pics now i can see the diffrence
