which is the best engine for subaru l series
Posted: Sat Jul 12, 2008 3:14 pm
by masterguitarshreader
Hi i have a 91 l series and a I am wordering what engine coversion would be the best to use with the standard l series 4wd gearbox i have been cosidering a ej20 non turbo any advice and a rough price estimate would be greatly appriciated.
Posted: Sat Jul 12, 2008 3:22 pm
by chubby37
ej22 would be better...you can buy adaptors thru the board to be able to use your old running gear...
Posted: Sat Jul 12, 2008 4:58 pm
by AndrewT
EJ22 gives u a little more power but not much difference. Overall you are probably better off getting an EJ20 because all the EJ22's are starting to get abit old these days.
Posted: Sat Jul 12, 2008 5:46 pm
by Gannon
So your a coffs harbour guy,.... sweet. Im from the nambucca valley, i was actually in coffs today
Being in NSW, an EJ20 would be your best bet as you will need an engineers cert if you go any bigger than 2L
Posted: Sun Jul 13, 2008 3:10 pm
by AlpineRaven
Check your local RTA for conversion with minimal engineers cert. For me I'd go for EJ22 over EJ20, but if you could get late EJ20 then thats good.
Posted: Sun Jul 13, 2008 5:27 pm
by Suby Wan Kenobi
Either of the EJ non turbo engines are the go, try to get one with the lowest amount of Ks on it. Beware that if you get a post 2000 model engine and electrical that you will need the ignition barrel and the key to suit the ECu other wise it wont fire.
