Gearbox stub axles
- Pommiebrat
Gearbox stub axles
Anyone able to describe how to swap the stub axles on an EA82 5 sp d/r transmission? Mine have 25 splines and I need ones with 23 splines (I think that's correct) to take normal brumby axleshafts.
John
John
That would be lot easier rather pulling gearbox apart to change the stubs.EJ22Ute wrote:have u considered changing the d/o joint to match the spline stub axle?
much easier than changing stub axle in gearbox imo.
- Pommiebrat
If found sometimes you need to mix and match between the 2 models but if my memory serves me right, last time I did this I used the Brumby drive shaft with inner joint off a early EJ18 2WD drive shaft, I think it was from a import Legacy or early Impreza
Definitely much easier than splitting the box... IMO
The MPFI L gearboxes are the same spline count as the Liberty CV's, yet the rear diff remained 23 splines for the male stub axle diffs...RSR 555 wrote:If found sometimes you need to mix and match between the 2 models but if my memory serves me right, last time I did this I used the Brumby drive shaft with inner joint off a early EJ18 2WD drive shaft, I think it was from a import Legacy or early Impreza
