low range selection trouble
mates Brumby is getting really difficult to get into low range, is there a known issue with the low range selector ? do they wear badly like the gearbox shifter ?
G'day mate, My suby had a bolt on the bottom of the gear lever that came loose and stopped it from changing into reverse, also it restriced the movement to the high/low range change somehow. Hope this helps
Cheers Ethan
Cheers Ethan
Current Ride - 85 Touring wagon, All electrics, KYB long travel struts, Power Steer, Mags (swapping for sunnies).
