the mrs 90 legacy wagon ej20T
stevonz24
Post by stevonz24 » Sat Jun 28, 2008 1:33 pm
hay guys could u please help me with a wee problem ....?
the mrs hasa ej20T 1990 legacy (liberty) wagon i did the water pump onit and pt it bk 2gether and now the auto dusnt seem to select gears, like theres no wee thunk wen selectd, and only moves slightly in any gear, and the mrs...pist at me :p
any ideas
Post by El_Freddo » Tue Jul 01, 2008 2:39 pm
I'd be firstly checking the oil, it may be a coinscidence that the oil level is low and the gearbox decides to play up after you've "toyed" with the motor. Otherwise I'd be checking all the vacuum lines to make sure nothing was knocked off during the pump install.
Also make sure your cam belt timing in correct, this may upset the auto.
stevonz24
Post by stevonz24 » Tue Jul 01, 2008 3:09 pm
oo thanx man, i put a tiny bit of auto fluid in it and it worked better, so think i'll get a auto filter and change oil. um dnt spose u have a link to a pic of cambelt timing? bit confused with the pattern behind the crankcog?, :???:
stevonz24
Post by stevonz24 » Tue Jul 01, 2008 3:38 pm
:mrgreen:hay dus nebody out there have a printable diagram of the timing belt layout for a EJ20T its a 1990 ????
chubby37
Post by chubby37 » Tue Jul 01, 2008 5:29 pm
stevonz24
Post by stevonz24 » Tue Jul 01, 2008 5:46 pm
thanx man much appreciated:mrgreen::mrgreen:
chubby37
Post by chubby37 » Tue Jul 01, 2008 5:47 pm
thats cool...hope it helps
