OIL pressure from EJ motor to EA81 guage...
What's the best way to make this work? Seems the EJ sender gives a signal that the EA guage can't read. Is there a trick to making it work other than shunting an EA81 oil sensor into the system and wiring that to the guage ?
is this your EJ20T brumby?
most oil pressure switches are just that, a switch, and not a pressure reader.
tey simply turn off the oil light on the dash when oil pressure is higher than the switches setting.
most likely id think you actually need to get a Presser sensor and replace the switch.
although i dont know much specifically about the EJ20T's i cant recall seing a WRX that had a Oil Pressure Guage so most likely wont have a Pressure Sensor.
Wagon is no longer....
- littlewhiteute
