locking the auto center diff
I am after a diagram showing how to lock the auto center diff with a switch on the dash
cheers seagull
cheers seagull
As far as i understand it...
The DutyC solenoid controls the pressure to the lock up clutch and thus the amount of torque to the rear wheels.
The TCU, which receives information from the ECU about engine load etc. which then determines the 'Duty Cylce' (pulsed 12v much like injectors) to be sent to the DutyC soleniod.
If you can intercept this signal, and supply your own, you can control the lock up clutch independent to the TCU.
All it would take is a Duty Cycle controller with a variable output and you could control the torque to the rear wheels from 0 to 50%
