Lib rear driveshaft measurements
Posted: Wed Jun 04, 2008 2:49 pm
by PeeJay
I'm after the following measurements from the later model plug type rear driveshafts:
1) distance from the end of the shaft to the snap ring groove (I think it's different on each side)
2) diameter of snap ring groove/snap ring
I need to mod the output stubs on my L series to fit the later VLSD diffs.
Thanks!
Posted: Wed Jun 04, 2008 8:29 pm
by AlpineRaven
Photos coming in few mins..
Posted: Wed Jun 04, 2008 9:00 pm
by AlpineRaven
Posted: Wed Jun 04, 2008 10:05 pm
by PeeJay
Wow Brilliant!! Thanks.
Posted: Wed Jun 04, 2008 10:16 pm
by AlpineRaven
Something came in my mind, early Liberty (Gen1 & 2) had male stubs - same as L series.....
Posted: Wed Jun 04, 2008 11:34 pm
by shuffbag
AlpineRaven wrote:Something came in my mind, early Liberty (Gen1 & 2) had male stubs - same as L series.....
this may help me.... my donour car for my L upgrade is a 1990 lib will i just be able to use my L drive shafts if i use its manual awd box?
Posted: Thu Jun 05, 2008 7:39 am
by AlpineRaven
I am not exactly sure (have the feeling it will fit on the gearbox) because I haven't came across to it.. someone else here might be able to answer it.
Posted: Thu Jun 05, 2008 7:40 am
by AlpineRaven
shuffbag wrote:this may help me.... my donour car for my L upgrade is a 1990 lib will i just be able to use my L drive shafts if i use its manual awd box?
If you like, I can find that out for you tonight as I have L series box & AWD box in the garage - that if no one replies.
Posted: Thu Jun 05, 2008 8:32 am
by shuffbag
yeah that would be great.
im trying to use as much of the lib befor i hand it over to the wreckers.
Posted: Thu Jun 05, 2008 6:26 pm
by PeeJay
If you use the lib diff you have to use the lib tailshaft, or change the thing that the tail shaft connects to on the diff to the L series one. L series tailshaft will fit AWD box. Either tailshaft will have to be modified to be the correct overall length.
If the diff has male output stubs, L series shafts will fit fine. If you have the stubless diff like mine, the only options that I know of are custom driveshafts or mod a pair of stubs to fit the diff by machining in a snap ring groove.
Posted: Thu Jun 05, 2008 6:28 pm
by PeeJay
If you were talking about the front driveshafts, they will fit if they are from an EFI model (I think). The others have a different spline count.
Posted: Thu Jun 05, 2008 8:15 pm
by AlpineRaven
PeeJay wrote:If you use the lib diff you have to use the lib tailshaft, or change the thing that the tail shaft connects to on the diff to the L series one. L series tailshaft will fit AWD box. Either tailshaft will have to be modified to be the correct overall length.
Thats right, otherwise you could change the flange from L series/Liberty type, both are different sizes.
Gen1 & Gen2 Liberty has different size flange. You will need a press and rattle hammer to undo the nut & press to remove the flange.
L series is the same as Gen1 Liberty.
Posted: Thu Jun 05, 2008 8:17 pm
by AlpineRaven
Had a look in the garage. Liberty has bigger stub axle than L series. But I'm not sure about the hub.
Its a possible that you could mix up the CV joints to fit? I cannot answer that - only way is to muck around..
