castellated nut
32ford
castellated nut
Post by 32ford » Wed Jun 04, 2008 11:54 am
has anyone out there used a paper or leather washer behind their castellated nuts at the end of the CVs. I have had a sh#t of a time getting one of them undone and was thinking that to avoid this problem a paper washer might make it easier next time. I have always used a paper washer on the chuck of the lathe as it is subject to the same type of shock loading , and it means you can always get the chuck off, without damaging the lathe or the chuck.
Post by Alex » Wed Jun 04, 2008 2:55 pm
never heard of this before.
i just use the two washers that come with it.
dfoyl
Post by dfoyl » Wed Jun 04, 2008 5:53 pm
The 36mm nut is easy to undo...attach socket on long breaker bar, put car in reverse and slowly let out clutch.
Not quite so easy at a wreckers or on a not-running vehicle. Big breaker bar and plenty of force...
Dean.
littlewhiteute
Post by littlewhiteute » Wed Jun 04, 2008 7:12 pm
36mm socket 3/4 drive breaker bar, not an issue, torque spec for the nut is 196Nm, 144 ftlb.
No point in putting anything soft under the nut.
Gary ;)
Morcs
Post by Morcs » Wed Jun 04, 2008 9:49 pm
Like they all have said they are always tight make sure they are lubed when you replace them etc. Use a longer lever. I have peice of 50mm stainless tube that i use over my 3/4 inch socket handle as a longer lever to (crack)the nut before i jack it of the ground (bigger socket Drive= bigger Jumps on lever(without Breakage)). Always needs to be tight as they make funny grinding noise if loose
So many optioins not enough time or money:confused:
Post by AlpineRaven » Wed Jun 04, 2008 10:10 pm
I wouldnt do that kind of thing because it'll wear down and cause free play then one day you'll hear funny noises and will drive you crazy. I do recall seeing washers and no washers behind the nut, always used breaker bar while the car is on the ground before I do further work on the car.
32ford
Post by 32ford » Wed Jun 04, 2008 10:41 pm
ok i get the message use more leverage, I just found that there was one really tight nut and it got me thinking about what I do on the lathe to prevent really tight chucks.
