ea81 lsd rear diff
heath
ea81 lsd rear diff
Post by heath » Thu May 29, 2008 3:51 pm
can anyone tell me if they made a lsd rear end in an ea81 if so dose anyone no where i can get 1
bluesteel
Post by bluesteel » Thu May 29, 2008 4:01 pm
its just an r160 diff
so you can make anything fit of that size, L series, wrx, rs, all the usual suspects
heath
Post by heath » Thu May 29, 2008 4:59 pm
thanks is there a way to tell what diff ratio i'm running in the front so i can match them up
daveosubi
Post by daveosubi » Thu May 29, 2008 5:02 pm
Theres a sticker on the rear diff of my L that has the ratio, im guessing it's on the my's too?
heath
Post by heath » Thu May 29, 2008 5:03 pm
thanks ill go look now
heath
Post by heath » Thu May 29, 2008 5:16 pm
just had a look and the sitcker is gone. all that i can find written on the diff is756 83 z kn26. does this mean anything to anyone
bluesteel
Post by bluesteel » Thu May 29, 2008 5:23 pm
you can either pul the rear cover off the diff and count the number of teeth 37=3.7 and 39=3.9
or you can jack the back of the car off the ground and put a mark on the wheel and the tailshaft
then you just count the number of turns it takes the tailshaft to spin the wheels once
eg 3.7 turns of the tailshaft to make the wheels turn once = 3.7:1 ratio
or you can just replace the diff centre with a LSD one
Phizinza
Post by Phizinza » Thu May 29, 2008 6:04 pm
bluesteel wrote:its just an r160 diff
You forgot to add that later model R160's (95 onwards or something) don't have stub shafts on the diff, they have the stub on the driveshafts joint. I think the joints are different too so it would require some driveshaft modification (chop and weld I assume) to fit on of these diffs in a narrower track EA81 car.
heath
Post by heath » Thu May 29, 2008 6:09 pm
ta think i'l pull the back of the diff of and count it this weekend. would change the diff centre aswell but things are a bit tight with the cash flow at the moment
ea82t_sports
Post by ea82t_sports » Mon Jun 09, 2008 12:05 am
so are there anydirect swaps for a l series to get a lsd happening this is just my daily i dont want to spend time customizing stuff to fit
Phizinza
Post by Phizinza » Mon Jun 09, 2008 10:29 am
A CLSD from an 85-89 Subaru RX should bolt right in. (not sure on the exact years the RX came out but someone will correct me.)
