I've been cleaning up a few things on the new brumby to get it ready for RWC, one thing I've noticed is that the reverse light wiring isn't hooked up. I can't find any wires on the gearbox to hook them up to, there's a set that appear to be for a lo-range dashlight, but I can't see any reverse wires.
Anyone able to point me in the right direction ?
Reverse wiring from liberty dual range gearbox?
- FROG
Should Be A Rev Light Switch Just Below The Nuetral Swich On Left Hand Side Of Transfer Case
It's a manual, so it wouldn't have a neutral switch i don't think? There's a set of wires hooked up which I assume are for the dual-range switch, the reverse switch cables from the car's loom are just hanging loose. I can't find a second set of wires coming from the gearbox.
aggh, just found the switch, the wires have been snapped off at the switch, so I'll have to try find a new one. The switch itself just looks like it unscrews with the use of an appropriate sized spanner ?
