I think my engine is ****ed..help
- littlewhiteute
if u where standing next to the car at thta point u would have lost hearing for a while:P
it did basically self distruct....i got concerns for the block...and so do my engine bulders...as this block is not cheap
dave
dave
- littlewhiteute
it is an ej20 closed deck block
already got the cossy pistons and rods, latest news is that the block is fine...just needs a slight grind on one of the crank seats where the bent rod was chewing at
littlewhiteute wrote:I'd be concerned for the block as well.
Sounds like you'll be up for a block, crank, rods (Eagle H beams or similar).
Closed deck block?
- littlewhiteute
i have cossy pistons and rods..HAHAHAHA cossie are THE most expensive brand that i know of for making rex gear......put it this way...a cosworth block...just the block is well over 10 grand......
cosworth heads are alone..worth wel over 6 grand....
pistons and rods are usually 2450 but i got them at a cheap price accidently....
i think the gear im getting is good enough :P
as for head gaskets...2 x custom made copper head gaskets....@ $ 390 each
in a word......no
and i dont trust second hand engines...not at all..in fact i ****n hate buying 2nd hand engines..theres always the chance of it blowing up again
Ej207 Ftw !
Hunter S. Thompson
Hunter S. Thompson
Ftmfl Alex
Hunter S. Thompson
Hunter S. Thompson
Epileptic fit!
j/j’s
FTW ‘for the win’
FTL ‘for the lose’
Ill let ya figure out the ‘mf’ bit yaself
FTW ‘for the win’
FTL ‘for the lose’
Hunter S. Thompson
Hunter S. Thompson
UPDATE
got my motor back from the shop toda
All the cylinders bored and honed and faced etc etc
Cosworth pistons and rods (resized)
racing bearings
New Crank shaft polished etc
Hastings Racing rings
Deisel liners
Fully closed deck
Heads ported and polished and shaved
Valve seats modified
custom red bits
now for the fun part of putting it all back together and getting it right
should be running by the end of the week
dave
racing bearings
Deisel liners
Fully closed deck
custom red bits
dave
MOTOR IS DONE!!!!!!
alex and myself finished putting her back together tonight...apart from the turbo so will definetly be in the car and running by the end of the week:D:D
bring on the power!!!!!:D:twisted::twisted:
dave
dave
I am sure you guys have re-built engines before and know more than me as I have only done three? ....anyhow I will add my two bobs worth....did you bother priming the oil pump and once in the engine bay are you going to pull out the plugs, disable fuel and turn it over till the oil pressure is up?
My brother's rangerover didn't pick up the oil when first starting up after a re-build, ran for 30 seconds and seized! Managed to turn it over again with both the starter and brute force on the crank handle (subarus don't have those)...It still ran however am sure the bearings were never the same!
