Should I see flywheel thru housing EJ22
Changed engine temp sensor yesterday. Noticed service hole thru housing of clutch under air inlet, should I be able to see the forward surface of the flywheel or should there be a rubber cover over this hole.
- ej 22 flywheel.JPG (40.85 KiB) Viewed 1431 times
yeah thats for the timing light area - normally the rubber seal or cover has gone hard and either fallen off or mechanic forgot to put it back in, once I found one inside the gearbox! I am sure subaru will have new one there, mine is missing as well.
