EA81 heads , some are different
I recall some saying EA81 heads differed in valve size. I have found one of my spare motors just stripped have two extra bolts M6? with 10mm head that are located at the lower side of the head and screw into the block, the other heads have a slimline casting boss? covering same hole on the headgasket.
Curious if anyone knows where this difference occured early, mid or late MY's praps?? Or just to help the gasket not leak ?j
http://www.ultimatesubaru.org/forum/sho ... hp?t=86623
have a read
i dont no nething bout them but. only had the one EA81 and turned out to be a Dual port...dunno if that meant big or small or what tho.
have a read
Wagon is no longer....
- BaronVonChickenPants
OK
I found I have one pair of smaller inlet valve heads ~ 40mm, they are the heads with the extra M6 10mm bolts. The RHS has a square and tapped lug tacked on and not part of the casting to accept the power steer bolt mount. Looks factory but as an after thought!!
the others are ~ 41.5mm . Not much difference really
and both have a chamber volume of ~ 250ml
I have a selection of pollution ports drilled and tapped too on some pairs
