EA82 Timing belt cover issues .
discopotato03
Post by discopotato03 » Sun Mar 16, 2008 5:24 pm
Hi all , every time I go to remove EA82 inner covers the brass insert in the plastic strips and you can't remove the bolts .
Are these available new and for what sort of money ?
Cheers A .
scrumpy
Post by scrumpy » Mon Mar 17, 2008 7:34 am
Hey, always have the same problem, end up cutting them off with cutting wheel on grinder, luckily they are the ones where I can put a bolt and nut on.
Regards, Pete
Post by Gannon » Mon Mar 17, 2008 4:39 pm
Leave em off???
I dunno how legal it is, but it looks cool
Plus you can see if your camshaft seals leak
Post by El_Freddo » Mon Mar 17, 2008 5:16 pm
Suparoo wrote:Leave em off???
hehehe... how true.
I'd be doing the nut and bolt trick with a few washers as scrumpy said... You'd get quite a bit of muck on those belts and they're covered for a reason. If you do leave them off i'd be checking the belt condition at set intervals as I'd reckon the chance of belt failure would dramatically rise.
Smokey
Post by Smokey » Mon Mar 17, 2008 7:55 pm
discopotato03 wrote:Are these available new and for what sort of money ?
I bought an inner passenger side cam cover (the large of the two) for about 70ish. I recon a full set would be a bit cheaper than individual.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Mon Mar 17, 2008 9:56 pm
When you put them on dont tighten them very much and they come off easy next time.
If someone else who dont know the problem they cam be very tight.
The long road ahead
Post by steptoe » Mon Mar 17, 2008 10:43 pm
Don't they just upset you greatly ? I now do them up with a little o ring to grip between bolt and cover - and not tight enough to cause grief next time around. It took me three motors to get a reasonably decent set. You almst need to surgically remove a third of the nuts surround and rebuild it with araldite or something .
