Engine differences
Engine differences
I need to know if there is a definite difference between an EA82T and non T engine BLOCK/CRANKCASE. I have found that my problems with the current engine are due to twisting the block so i need a new one asap so i can get it back on the dyno.
To combat this im going to introduce more dowels and studs, ill keep u informed on how it goes
- Suby Wan Kenobi
But non turbo MPFI blocks do have that vent/seperator thingy
twisting the block, wow
Correct. I dunno if they have a spot for the knock sensor though. The MPFI non turbo's don't have a knock sensor, but from what i have read i believe the turbo's do run the knock sensor...Suparoo wrote:But non turbo MPFI blocks do have that vent/seperator thingy
PS, would like to know what you were doing to the engine to twist the block!
- discopotato03
- Suby Wan Kenobi
I have not ever seen an NA EFI block in the workshop, the only EFI i see in an EA is a turbo one.
As for knock sensor i remember the mark on the block but i dunno if the thread is there for the knock mount
The long road ahead
The long road ahead
Australian MPFI's were avaliable between 88 and 90 in the touring wagons. They had the 4 plug ecu system
