Spark plug on cylinder no 2 was significantly loose.
even if i tried to tighten it a bit, you could hear that sound of gasses coming out.
i put in a spark plug repair kit, basically tap and re-threaded the head, and inserted a sleeve onto the spark plug. i applied liberal amounts of grease onto the tap, in an effort to catch as much of the aluminium shavings as I could.
car runs, no noise from around the spark plug, but there is a little evidence of gases coming out, using a little WD40, there were bubbles forming around the plug.
im out of ideas (and luck). what can I do now?
time for a forester me thinks.
HELP! - re: spark plug
1998 Subaru Legacy GTB
