EA82T to 4 speed, what clutch set up ?
There has been talk in here at times asking if a Brumby/MY 4 speed box would handle the EA82T 'power' . As you'd almost have to use an EA82 flywheel (wouldn't you?) therefore pressure plate. What drive plate would you use ?
Raises another question. The input shaft splines on MY boxes, were they the same for both diameter clutches used ?
Thinking that the torque of a 4 speed behind an EA82T would be interesting. Torquier ?
i dont think the box will handle the power at all tbh lol but in sayin that i will be bolting up a 4speed behind an EJ soon enoughjono wrote:There has been talk in here at times asking if a Brumby/MY 4 speed box would handle the EA82T 'power' . As you'd almost have to use an EA82 flywheel (wouldn't you?) therefore pressure plate. What drive plate would you use ?
input shaft spliens as far as i know were same
and driveplate ? if by that u mean Clutch Disc then ud need the EA81 disc as it has correct splines and ud alos need it as same diameter as flywheel and pressure plate
Wagon is no longer....
i had a weird 1 last week i have a 1986 ea82 na leone fwd sedan right i was doin the clutch/pressure plate/flywheel.....easy u say lol well...me and Bluesteel (thanxs m8 ) pulled the box out easy part:) loked at the clutch kit that i got ...um too big whats goin on here pressure plate and clutch plate were too big ok , cool cool ill get the fwd clutch kit no worries....the  bit that baffeled got us wondering why the clutch kit was so wrong....
so i got my very good m8 around Will ( My_Sti) he had a look and straight away was like "um i think thats a ea81 gearbox in ur car m8" clutch fork was on the diff side and the input shaft was a 21 spline shaft.... hmm...hmm whats going on here and in the mea time i brought a lightened flywheel for the ea82 so i have a lightened flywheel and an rpm heavy duty clutch kit that i cant use but sir will had a brain wave lets use the 82 flywheel the 82 pressure plate but we get the 21 spine 9" 81 clutch disc...hmm im thinking cool but the throw out bearing is different nope all good we can use the 81 bearing no worries....ok then but then the last prob was the new flywheel was 5mm smaller then the old 1 so we have to soace the hell out of the clutch fork adjustment
so after all that i have a ea81 gearbox/clutch plate/throw out bearing..and a ea82 pressure plate/flywheel..phew srry for the long response lol cheers BEN
						- BaronVonChickenPants
The EA81 and EA82 flywheels have the same bolt pattern for the engine but they also have the same bolt pattern for the pressure plate, so just check out which of the flywheels you have will take a 9" clutch and get the EA81 9" kit.
Having said that, if you're going to all this effort for the engine why are you staying with the MY 4 speed? Although it's technically a weaker box I'm sure it would handle the power of a standard EA82T, for a while at least, but that extra gear makes it so much nicer to drive.
I doubt there would be any gearing advantage, from memory the ratio's were close enough to identical except theres another gear between your current 3rd and 4th.
Jordan.
Jordan.
Wow that certainly is strange. So the whole time you had the car you never wondered why your L series had only 4 gears??subelover wrote:i "um i think thats a ea81 gearbox in ur car m8" ..........
so after all that i have a ea81 gearbox..............
EZ30 L series - Monsterwagon
Well, l don't know much about the 82 clutch hook up, l can tell you for sure the box will handle the stress, (within reason of course), my ute although an 81T,  has quite a bit more horsepower than the standard 82T has run the humble 4 speed for nearly 2 years now without a hiccup on a standard 81 clutch set up. What you might not like is First gear though.
									Redskin
89 Brumby
EA-81T.
						89 Brumby
EA-81T.
