what are these?
LTurbo
what are these?
Post by LTurbo » Mon Nov 28, 2005 7:24 pm
Okay, I just installed this gearbox into my car (5-speed dual range). I was just wondering what these two pins are for sticking out of the dust boot? They are threaded so something bolts down onto them.
Guest
Post by Guest » Mon Nov 28, 2005 7:46 pm
Fixed the pics for ya 8) Webshots won't let you use pics that they've hosted, think it saves them on bandwidth.
Looks like the mounts for the 4WD-engaged light switch.
adam_rxturbo
Post by adam_rxturbo » Mon Nov 28, 2005 10:29 pm
yep mudrat is spot on. There is a little switch which the lever hits when you select low range - lights up an organge box saying 'lo' in the car indicator display thing...
I have the exact switch hanging off my old gearbox gearstick linkages. But you'd have to have the wiring + connector hidden under the carpet to connect up the switch (wiring should come from around drivers footwell, up the side of the centre console, then accross the back to where those 2 studs are. i think from memory the connector is blue and rectangularish.
Hope that helps 8)
-Adam
Guest
Post by Guest » Mon Nov 28, 2005 10:32 pm
adam_rxturbo wrote:i think from memory the connector is blue and rectangularish. Hope that helps 8)
A truely quotable quote. Quick someone stick it in there sig!!
adam_rxturbo
Post by adam_rxturbo » Mon Nov 28, 2005 10:54 pm
ROFL :lol: it was the best i could do :wink:
LTurbo
Post by LTurbo » Tue Nov 29, 2005 9:15 am
Thanks guys just wanted to make sure it was not anything important. The gearbox is now in what was a allwheel drive automatic car so there is no 4wd Low light on the dash, and there is no way I am swapping dashes so I can have a silly little light.
LTurbo
Post by LTurbo » Tue Nov 29, 2005 9:17 am
MUDRAT wrote:Fixed the pics for ya 8) Webshots won't let you use pics that they've hosted, think it saves them on bandwidth.
Huh? really, so no one can see any of my other pics? that sucks, any suggestions on what pic hosting site I should use then?
smoov
Post by smoov » Tue Nov 29, 2005 9:21 am
its like no one listens to me :cry:
http://www.imageshack.us
best.
evarr.
1998 Subaru Legacy GTB
LTurbo
Post by LTurbo » Tue Nov 29, 2005 9:30 am
smoov wrote:its like no one listens to me :cry:
awwwh, I am sorry, you gonna be alright? :lol:
But anyway thanks for the link.
Guest
Post by Guest » Tue Nov 29, 2005 3:02 pm
If you look in the dialogue for your post Thomas you'll see that I just posted them in the USMB gallery. Works fine for me!
