ea82 and 82t differances
waggaclint
Post by waggaclint » Sat Mar 03, 2007 4:33 pm
can somebody tell the exact differences between these motors visually i mean and are the earlier ones different to the later ones (ie can you fit a later spider manifold to an older motor....reason is ive aquired one one and the only thing i can see different is the inlet ports on the head everything else looks the same.....also it doesnt have a manifold so id like to put a spider type one on it....cheers clint
2011 Forester X
Post by Gannon » Sat Mar 03, 2007 7:33 pm
So you have a spider manifold and you want to put it on the motor in your car? What motor do you have?
There were 3 versions of the EA82 avaliable in Australia
-Carby'd... which has one inlet and exhaust port per head.
-MPFI and MPFI Turbo... which has 2 inlet and one exhaust port per head.
Basically the EA82 MPFI and the EA82T are the same motor, the only differences being:-
-EA82T has lower compression 7.7:1
-It has a different camshaft (intake opens earlier)
-Has coolant and oil ports on the drivers side head
-It has a turbo, which is an IHI RHB5 VF4 (VF7 in USA)
There are two electrical systems, read Differences between 3Plug and 4Plug ECU's
Your spider manifold was avaliable on MPFI and Turbo Vortex's. Im pretty sure that it was only avaliable to the 4plug models (87-94) but if you are tricky, the electrical can be adapted. They bolt up to all MPFI and TURBO motors, not CARBY
Hope this clears things up
waggaclint
Post by waggaclint » Mon Mar 05, 2007 11:11 am
Suparoo wrote:What motor do you have?
i have the 2inlet one exhaust motor it is not in the car ive only just got...its only the block the inlet manifold is missing and wiring etc as well...so i will be able to put a spider manifold on it...the turbo is missing too but i have turbo exhaust manifold....im going to rebuild it 1st then ill chase up the missing parts and drop it in....cheers
2011 Forester X
Post by steptoe » Mon Mar 05, 2007 9:58 pm
apparently the throttle position sensor works differently between spider manifold and normal efi tps but has been rejigged to work by someone in here.
Block differences include a pcv plate at the back of the block behind flywheel/flexplate and a large 16mm vent pipe abpve comes out top of block close to back on the driver side block.
Post by steptoe » Mon Mar 05, 2007 9:59 pm
oh and a knock sensor...did all mpfi have them or only turbo?? screws in to the left of pcv vent pipe
subanator
Post by subanator » Mon Mar 05, 2007 10:45 pm
jono wrote:oh and a knock sensor...did all mpfi have them or only turbo?? screws in to the left of pcv vent pipe
All MPFI (including turbo). Note that the knock sensor is different for 4-plug ecu to 3-plug ecu too.
BlackMale
Post by BlackMale » Tue Mar 06, 2007 7:53 am
subanator wrote: Note that the knock sensor is different for 4-plug ecu to 3-plug ecu too.
and you do not need to wire it up.
Oh and waggaclint i can not remember if your is a MPFI or carb, and if you know that if its a carb motor then the fuel tank, fuel lines ecu, etc will require changing as well, which make this conversion a much bigger job.
Post by Gannon » Tue Mar 06, 2007 4:08 pm
subanator wrote:All MPFI (including turbo). Note that the knock sensor is different for 4-plug ecu to 3-plug ecu too.
Im pretty sure that only the Turbo's had a knock sensor, My mpfi doesnt have a knock sensor.
Rabbitoh
Post by Rabbitoh » Tue Mar 06, 2007 4:43 pm
Suparoo wrote:So you have a spider manifold and you want to put it on the motor in your car? What motor do you have?
Further query regarding EA82T , how do you tell what year it was made. I have a AX7 model from a turbo vortex.
Xtreme_RX
Post by Xtreme_RX » Tue Mar 06, 2007 4:53 pm
Suparoo wrote:Im pretty sure that only the Turbo's had a knock sensor, My mpfi doesnt have a knock sensor.
I agree. My 1989 MPFI Leone Royale has no knock sensor....
http://www.subiparts.com.au
0438 887 746
waggaclint
Post by waggaclint » Tue Mar 06, 2007 8:16 pm
yeah mines a carb model..ill just chase up a complete efi tank...as for wiring im gonna run a microtec (i can get a good deal on em) it will be easier that way....going off what everybody has been saying the motor i have is a turbo one so thats good anyway just gotta pull it apart now and see how good it is one timing belt is missing so someone has been playing around hopefully the motor is all repairable if anything is broken time will tell anyway...
2011 Forester X
Post by steptoe » Thu Mar 08, 2007 9:24 pm
and each block half has a casting date just above the last back sump bolt on each side to get an idea of how old it is
waggaclint
Post by waggaclint » Fri Mar 09, 2007 8:49 pm
check this one out wonder if ya can buy em in aus like that,,,
http://cgi.ebay.com/ebaymotors/ws/eBayI ... &rd=1&rd=1
2011 Forester X
