L-Series 5spd dr Questions
- schultzie
can i safely drive my L with the rear part of the tail shaft out?
i ask because as the car is now finally on the road it has got a severe vibration above 60kmh which is coming from the tail shaft.
i know it is coming from there because we took a section on the tail shaft out and the vibration is gone, checked the uni's but there is bugger all movement and dad and i cant work out why the vibration is so bad, i had a guess that the rubber donut might have had something to do with it but i have no idea.
thought about going to the wreckers and getting another tailshaft just an idea though... i just thought i would ask here first.
- Suby Wan Kenobi
With MY boxes, oil pours out as soon as u take the tail shaft out... L series boxes wont pour out when the car is still.... but i think it is a fair guess that when u take off and the oil moves to the back of the box it would come out.
Covering it with something might be ok for a quick test to see if thats the problem but i certainly would not leave it like that for more than a few hundred meters.
Dave
Dave
I think Schultzie might be referring to the rear part of the L-Series tailshaft from the centre support bearing back to the rear diff. If it is only this section that is removed then there will be no oil leakage problems as the transmission is still sealed by the front half of the tailshaft that runs from the transmission to the centre support bearing. As for running with the rear section of the prop shaft removed I think it should be OK, I'm fairly sure a friend of mine has done this and driven a few hundred k's like it after a uni joint seized on him while he was a fair way from anything in northern WA.
- schultzie
that is exactly what i was talking about gremlins, the 2nd peice of the tailshaft.
i wouldnt be silly enough to pull the front half out.
i'm fairly sure it is the uni's but what i think i will do is go to the wreckers and get a tailshaft off another one and see how that goes. if that fails then it will be off to get new unis
all fun though.
How goes you L-series now of days gremlins? comeing over our way any time soon im sure that not only myself but my folks would look forward to catching up with you gurs again...
Thanks Justin
Thanks Justin
