Brumby clutch
Post by steptoe » Thu Apr 21, 2016 7:55 am
Greedy bugger FROG, you gonna hoard them ? Can't say I have seen them on EA82, so specific to manual EA81's ?
FROG
Post by FROG » Thu Apr 21, 2016 9:13 am
steptoe wrote:Greedy bugger FROG, you gonna hoard them ? Can't say I have seen them on EA82, so specific to manual EA81's ?
Not hoarding Jonno , just keeping the last few within the Ausubaru family :)
and yes only EA81
Post by El_Freddo » Thu Apr 21, 2016 7:01 pm
Is this the smaller orange O ring on the back of the crank?
I remember someone telling me not to touch that I ring and leave it as is.
So that's what I did and no leaks ;)
David D
Post by David D » Sat Sep 03, 2016 3:55 pm
Still hoping to do this at some point. Long story short - 'replacement' for the Brumby (bigger family, extra seats etc.) is taking longer to hit the road than I expected.
Anyway, I picked up a flywheel at U-Pull-It which I'm hoping to clean up to swap with mine to save a bit of downtime. Are there any differences in these MY flywheels I should be aware of or should this one be OK? It came from an MY wagon.
David D
Post by Bantum » Sun Sep 04, 2016 2:00 am
I think the flywheels should be the same, its just the clutches that come in different sizes from memory - I'd confirm that with someone who knows more than me though ... :/
Cheers, Bantum ...
Post by TOONGA » Sun Sep 04, 2016 11:15 am
Two different sized clutches means 2 different sized flywheels.
200mm and 225mm from this thread showthread.php?t=19328 and personal experience
David D
Post by David D » Mon Sep 05, 2016 8:31 pm
Thanks for that. I guess I have a 50% chance of this one being right so I may as well get it ready to swap in.
David D
Post by David D » Mon Oct 03, 2016 8:15 pm
What sort of sealant has anyone used on flywheel bolts? I think I've got some of that non-hardening aviation gasket goo from when I did my inlet manifold gaskets. Would this work ok?
David D
Post by El_Freddo » Tue Oct 04, 2016 7:13 pm
I don't remember using a sealant on those bolts. But it's also been a while since I've worked in that area on the EA81 ;)
David D
Post by David D » Mon Oct 10, 2016 7:30 pm
Getting closer now, just picked up Silverbullet's crane the other day (thanks again).
Just wondering if anyone has pics of where to attach the crane to the engine. Hopefully will make sense when I go to do it but, just incase, would be nice to know what to look for.
Thanks
David
Post by Silverbullet » Mon Oct 10, 2016 9:15 pm
There should be a steel lifting hook bolted at the front of the engine block, right above the crank pulley. There should also be a steel bracket on the bell housing that you can put a D shackle through.
Here's a (really!) old pic I found on my PC, hopefully you can see the hooks on this pic.
262145_1662423060827_6445695_n (Medium).jpg (104.35 KiB) Viewed 15711 times
David D
Post by David D » Tue Oct 11, 2016 8:23 pm
Thanks, that's just what I need.
David D
Post by David D » Wed Oct 12, 2016 6:33 pm
Got the engine out today and took the clutch out to order a new one. Should be here tomorrow - 225mm and 21 splines just for info.
Everything came apart ok, the trickiest bit was actually separating the engine from the transmission. Had to wiggle it about a fair bit to get it free from the studs. It was also a bit tight getting my trolley jack under the transmission with the crane in the way. At least it's out.
The surfaces of the clutch and flywheel are almost like chrome - no wonder it's been shuddering. Also, the flywheel I got from U-Pull-It seems to be the right size! Came up great after machining.
Now I just have to fight with the flywheel bolts and do the rear main seal before putting it all back together.
David D
Post by David D » Thu Oct 13, 2016 7:10 pm
Got the engine back in today, went in ok apart from the last 50mm or so. Everything was lined up but I just couldn't seem to get the block to meet the transmission. Lots of jiggling and wiggling and pushing and pulling and swearing got it there eventually.
I also swapped the steering rack for a (hopefully) better one which took a bit of time so I haven't connected everything back up yet.
Already dreading the restart - always wonder if I've done something wrong or forgot something.....
David D
Post by David D » Fri Oct 14, 2016 7:29 pm
Got everything back together and took the car round the block today. Didn't go far but i can still drive it and change gear so hopefully all will be good. Won't fully relax until I get a few more kms under my belt tho....
Post by El_Freddo » Fri Oct 14, 2016 7:52 pm
Didn't go far as in you didn't drive it far or it didn't let you drive it far??
You've done well mate. A lot of people shy away from a clutch change thinking the cost makes it a task beyond anyone who hasn't been trained to do one...
Post by Silverbullet » Fri Oct 14, 2016 8:00 pm
That's great news! :) Well done on the first time swapping a clutch in an EA81 ;) And yep that last 50mm is always the hardest part, if you don't have a clutch alignment tool (or a cut off input shaft stub :mrgreen: ) makes it all the more frustrating.
David D
Post by David D » Sat Oct 15, 2016 7:44 am
Thanks guys
Bennie, I meant I didn't drive it very far - just a quick test drive.
It was a big job but more in terms of the amount of things to do rather than difficulty.
And yeah, Silverbullet, that cut off input shaft works a treat - everyone should have one!
David
