Fuel
Vortex75
Fuel
Post by Vortex75 » Sat Mar 22, 2014 3:42 pm
Hey, just wondering what fuel people use in their Subarus? Premium?
Esubie
Post by Esubie » Sat Mar 22, 2014 6:28 pm
I try to use the mid grade 95. It will run on anything tho.
1985 L Wagon DL. Carb. EA82. Stock.
Post by Gannon » Sat Mar 22, 2014 7:28 pm
If you have a turbo vortex, run it on 98 only.
The engine would have been designed for 95, but with 98 in in, you should be able to advance the timing by a degree or 2 and get a few more horsepower out of it
Post by steptoe » Sat Mar 22, 2014 8:43 pm
One EA82T is running 109 RON, my Vortex EA82T likes the Caltex/Woolworths Vortex 95
Vortex75
Post by Vortex75 » Sat Mar 22, 2014 8:49 pm
Yep. I use vortex in the Vortex
Venom
Post by Venom » Sun Mar 23, 2014 10:31 am
I use 100 Ron from the United Servo's.
Post by TOONGA » Sun Mar 23, 2014 10:35 am
I run my vortex on 91 mind you I have an EJ22 in her and a computer that will let me run on 91 :)
But for the turbo use premium
http://www.youtube.com/watch?v=dceB3SKBw9w
Post by RSR 555 » Sun Mar 23, 2014 11:39 pm
As these car were designed and built to run 100RON fuel in Japan, then 100RON fuel from United Fuels is your best option but I'm not convinced that the ethanol in it is any good for Subaru engines. I've seen many different reports. I prefer to use BP Ultimate 98 in my cars. I find they perform so much better and even get more kms per tank full.
If you are talking about using it in your Vortex, then I'd return with higher octane fuel and you'll get the most out of your engine.
Post by steptoe » Mon Mar 24, 2014 11:53 am
if you have a metal fuel tank, you don't want any ethanol percentage fuel in it for any great length of time.
Post by Gannon » Mon Mar 24, 2014 8:30 pm
I ran E10 95 (only premium available) in my EA82T for 2 years an have run E10 91 in my Outback for over 4 with no issues
Post by Silverbullet » Mon Mar 24, 2014 8:43 pm
So am I just wasting primo fuel by filling my Brum with 98 every week? :-o Only a recent change, but the engine runs so so much better with it. More power in every rev range and no more pinging full stop. It's worth the extra money to feel the extra go every time I put my foot down in top gear :)
ktmtragic
Post by ktmtragic » Tue Mar 25, 2014 8:27 pm
The dentist says sugar is no good for your teeth I say therefore it is no good for your engine. Ethanol is pure sugar end of story. It will eat everything like it eats teeth. You can't convince me to put that stuff anywhere near a vehicle I own. I came to OZ from Zimbabwe a long time ago and saw what government mandated ethanol ratio's did to perfectly good engines there. My advice is DON'T do it
Vortex75
Post by Vortex75 » Wed Mar 26, 2014 9:08 am
Not touching ethanol. If its meant to be 100 RON, what about Premium with an added octane booster?
Post by steptoe » Wed Mar 26, 2014 12:26 pm
The handbook for AUDelivery says engine was designed to give satisfactory performance and low emissions on 95 RON
And reading further in the booklet for Australian Models states was designed to run on 90 or higher unleaded
Does not differentiate between NA or turbo models
Venom
Post by Venom » Wed Mar 26, 2014 3:21 pm
List of cars that can use ethanol blends
http://www.fcai.com.au/environment/can- ... nd-petrol-
Esubie
Post by Esubie » Wed Mar 26, 2014 5:19 pm
Venom wrote:List of cars that can use ethanol blends
in short "not good for Subies" then ?
That was my own conclusion after I used it just once. Then I went back to 95 or higher.
ktmtragic
Post by ktmtragic » Wed Mar 26, 2014 5:39 pm
Posted verbatim from the link "As a solvent, ethanol attacks both the metallic and rubber based fuels lines, and other fuel system components.
Ethanol also has an affinity to water that can result in corrosion of fuel tanks and fuel lines. Rust resulting from this corrosion can ultimately block the fuel supply rendering the engine inoperable. Water in the fuel system can also result in the engine hesitating and running roughly."
I rest my case
Esubie
Post by Esubie » Wed Mar 26, 2014 7:52 pm
Also it's very telling that the bowser has on it "not for use in any aircraft".
Davidov
Post by Davidov » Thu Mar 27, 2014 1:05 pm
I use 100 from United in my JDM WRX engine as that is what they are designed for. Im not sure it offers any benefit at all over BP98 however it is much cheaper also so win win. :)
I found the difference from something like caltex 91 - BP 98 was enormous when I had an NA. At least a 15% increase to fuel economy and decent performance boost.
Subyroo
Post by Subyroo » Thu Mar 27, 2014 4:56 pm
I have used E10 in my Forester just the once, it ran like a sick dog at the track, never again will i put E10 in a car I own.
My mate has a 2013 Honda CRV 4WD VTi-L + ADAS 2.4L i-VTEC, he put E10 in 2 weeks ago and it was returning 13 L/100k around town where on 95RON he was getting 9.5 L/100k, he too has vowed & declared never to use E10 again.
He used to use E10 in his Subaru Imprezza before he sold it and it jerked and shuddered badly.
Peter
