Dual range sedan lever
- bensmith87
Hi all,
I've put a dual range gearbox into a 1997 RX sedan from a 2.0 2000 forester. It's all working great, however I'm sick of popping the bonnet to get low range.
Does anyone know if I can get the entire console and lever out of a 2nd gen dual range outback and it will just bolt in, or if there are some nuisances that I need to consider?
Is your 97 RX a Liberty or an Impreza?
If its a Liberty, the Outback console will bolt straight in, if its an Impreza, use a Forester console
- bensmith87
- d_generate
Why not just cut a slot in the console you have now? It's what I did here.
Hes correct.. Gen 1 & 2 liberty has the same cable but Gen 2 has different colour lever but basically both same.Gannon wrote:Is your 97 RX a Liberty or an Impreza?
- bensmith87
- bensmith87
- bensmith87
G'day,bensmith87 wrote: I think this is how the cable is ment to run...
The cable position is incorrect, it should be on the right side of the shifter, if you leave it like that you'll notice shifting doesnt feel right as its rubbing.
