Help changing turbo gearbox
Guys well I am helping Adrian change the geaarbox in his Forester GT after the centre diff shat itself..
Now we have disconnected everything but can't the the gearbox off the back of the motor... It's about half way off, got stuck then we realised you need to take the pin out the side for the clutch fork.
The problem is we can't get the pin out now or get the gearbox to move completely onto the motor, it's all just jammed and we don't really know what to do...
Is it likely we have bent the pin or what?
Any tips to help get it out and get the gearbox off...?
Thx
Thx
- d_generate
Why didn't you take the rear housing off and swap the center diff over, no need for box to come out, sometimes if those pins get dry they can rust a little and get stuck......long bolt and beat the shit out of it by making something like a slide, maybe long pair of pliers over the bolt shaft and smack it hard.
Got the pin out
With a big 1m pry bar and hammer, came out straight an unbent. Only took a few mins, was getting frustrated by the end of yesterday.....
Got the box off too, by myself. Now that was hard with just one person but I did it
When putting the new box on do I need to put this(thrust bearing is it??) on the gearbox spline an fit the clutch fork before putting the new box on?
Be careful when removing the thrust bearing or you might **** it up. there a little pin like was explained above. Put the pin back on the new gearbox and the thrust bearing on the pin. Once the motor and box are together, you can ingage the trust bearing by pushing the fork lever by hand and you will feel it go in. Also you will know thats its in as you won't be able to push the clutch in by hand.
Enjoy:)
Enjoy:)
hey dude, on a side note... the old box does it happen have that tube that screws into the box and the speedo cable plugs into the top...? i am in dyer need of one.. chuck me a message on 0430955187 if so
to do list:
to do list:
