Ea81 welch plugs
Ea81 welch plugs
Just wondering how i get the welch plugs in heads out? And also where else are they located
- Brumby Kid
3 in each head, rocker cover side, 20mm use brass. And supposedly there are 2 in each side of the block. Not sure how to get them out though.
yes, was, gonna suggest that, drill hole in plug first to suit a screw. For safety use a piece of something to limit drilling depth. Can't leave plug in head...hang on.....
shoot you act fast, first asking where and how and fifteen minutes later you have one stuck inside head ?
Have done just your trick but twice before I figured to drill and screw and pull or just lotsa little holes to the side of flat of plug to help collapse it.
One plug actually fell out block side holes, the other well, felt it was a throw away but persisted and got it, wishing small slip jointed angle pliers existed! Bigger slip joint will be enough to pull with screw in firm I found with 10 and 12mm plugs
Two? in each side of the block - rumours BK or prove it
other info is correct 3 x 20mm brass
How is progress, engine out ??
The ones in the block arent welch plugs, they are screw in plugs and you need a maybe 17mm socket to remove them, but I dont know why you would.
- Brumby Kid
I was told when I asked months ago, by someone possibly by the name of steptoe, that there where 10, 6 in the heads and 4 in the block.
Stuff happens oh well, Gannon fixed.
Cheers Cam
Cheers Cam
- Brumby Kid
Have you got any pics of the heads or gasket? If the heads were not torqued right or were warped that would do it unless you can see signs of a blowout on the gasket. What we want to know us why it did it especially seeing as you did it not long ago.
I think it is because the bolts keep viabrating loose, i didnt have to crack the driverside (problem side) where as the other side were alot tighter then the torqe settings, i realised it when i checked them a week after doing the gasket last time but didnt think much. I will use some lock tight, try see how that goes, fishing trip to test it.
How many km do you get from a tank? I get on avereage 5 to 6 hunder, normal?
- Brumby Kid
What are you getting L's per 100km?
That's easier to compare.
